idle air control valve
Old 04-25-14, 11:54 AM
i have a 1990 ford/pu f-250 302 5.0 L when replacing idle control is it just a swap out or are there any adjustments that need to be made my other question is when replacing the gasket with it do i need to use some kind of gasket sealer
Old 04-25-14, 01:49 PM
XSleeper's Avatar
It's a swap. Should come with a new gasket.
But have you tested the existing one with a multimeter to see if it's really bad? I wasted $90 replacing mine a while back, thinking it was the source of my idle problems. Learned my lesson there. Now I do my homework first.
Old 04-27-14, 11:51 AM
gasket
xsleeper when you put your air idle control on did you use anything for the gasket or did you put it on dry
Old 04-27-14, 12:16 PM
XSleeper's Avatar
The idle air control valve generally comes with a new gasket. If not, you can either get one or make one.
http://contentinfo.autozone.com/znet...90102/image/3/
My f150 is a little newer than yours, so it has rubber gaskets, not paper ones.
