2001 Ford Ranger, Ignition coil
Received 0 Votes
My truck is missing every now and then so I'm replacing the ignition coil (this will be the 4th thing I've done), but the ignition coil I'm replacing has 3 mounting screws (2 in the front, one centered in the rear) and every replacement coil I've seen has 4 screw mounting. This is for the 3L/6, gas-only engine. Am I not seeing something?
thanks - Mark
thanks - Mark
It's pretty rare for the coil to cause a miss.
I'm guessing you've already changed the plugs and wires ?
You mentioned ignition coil. Does your engine have a cap and rotor or a newer style coil pack where all the plug wires connect to it ?
