RV Dash Heating and Cooling System
Received 0 Votes
My 2001 Dutchstar RV will not switch from defrost vents to regular vent or floor vent. I found the fuse for the vacuum pump. it is ok. is there a way i can manually get to vent to switch. i just want the air to come out of the vent ducts instead of the defrost ducts. Thanks.
Welcome to the forums.
There should be a silver vacuum motor with linkage that you could disconnect and lock in regular vent position.
I'm not sure where it is on your unit. I'll try to locate it for you.
