Please help me identify this Avalanche part......
Received 0 Votes
this fell off of my 2002 Chevy Avalanche this morning. Any ideas what it is and how dangerous it is to NOT have it on my vehicle anymore?
If it really fell off your vehicle (which I sort of doubt) yes, it's very dangerous. It's part of the suspension/steering. Though it's hard to say exactly what, it looks like it could be part of the center link. It should be very easy to find by getting under the truck with a flashlight.
I'd be very surprised that you wouldn't have noticed screeching and wobble as you drove before it broke off (if it broke off). The ball joint is dry as a bone and very worn.
If you or a friend can't find anything, then have it towed (do not drive it) to a shop with a lift so the can inspect the steering and suspension.
That appears to be part of a sway bar. They are on front and rear axles. Check both axles for remaining pieces. If sway bar is the case, then you can drive it, but carefully as it will tend to rock like a boat.
RR
RR
I don't think I've ever seen that big a ball joint on a sway bar?? Of course I haven't had a full size truck in a while, either.
When I was looking at the parts diagrams, the shape didn't seem right for a sway bar end.
Visual inspection should find it pretty easy.
