'95 Chevy 1500 (Silverado) 4X4 ext cab turn indicator issue
Old 08-24-14, 02:33 PM
U
Turn indicators don't work. Both dash turn indicators illuminate when I step on the brakes. All fuses appear intact in both fuse/relay panels. Emergency flashers don't work either. Truck is new to me and have no owner's manual.
Old 08-25-14, 05:47 AM
W
Received 31 Votes on 28 Posts
Turn Signals
You need a new flasher unit.
Old 08-25-14, 04:43 PM
U
Thanks. Where is this flasher unit located?
Old 08-26-14, 05:49 AM
W
Flasher
Look under the dash to the left of the steering column.
Old 08-27-14, 07:26 AM
U
Thanks Wirepuller, I really appreciate the help. Next question: the warning chime is not working. As mentioned earlier, all fuses appear intact. Next to the flasher unit (which was out of socket btw) is the word "chime" and a (possibly) empty socket shaped like an elongated capital"D". Is it possible I'm missing a 'chime unit'?
Old 08-27-14, 08:30 AM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Very likely. Bottom diagram of the first reply here....1995 Chevy Truck Fuse Box: Electrical Problem 1995 Chevy Truck V8 ...
Old 08-29-14, 12:35 PM
U
Thanks again for the help. Next question: what's the procedure and/or tool for removing the circular door switches from the sides of the dash pad? Both of mine are bad so I cut two 'new' ones out a truck at the local junkyard and still couldn't see how it should be done.
Old 08-29-14, 12:47 PM
Gunguy45's Avatar
Super Moderator
Can't help you there, not familiar with that interior. Do you mean in the door or the actual dash?
Old 08-30-14, 09:48 AM
U
I'm going to start a new post; Thanks again for the help.
