2001 Dodge 1500 4x4 Ram 318L. Oil pressure issue.
Old 11-23-14, 08:48 AM
My oil pressure gauge went from 40psi to zero while just going down the interstate. No knocking occured as if I still had pressure. I cut off the truck and the guage went back to 40psi and then dropped back to zero. Someone said it could be the oil sending unit sensor. I looked it up and could not find where it is located. My truck does not have a distributor so it cant be there. Any help?
Old 11-23-14, 10:27 AM
chandler's Avatar
Received 4 Votes on 4 Posts
Not sure where the sending unit is on a gasser, but that year model, everything is electronic. Even your speedometer and tachometer. I would locate the sending unit and replace it. It will be on the side with your oil filter. You don't have a distributor? Does your "check gauges" light come on with a ding when it drops pressure?
Old 11-23-14, 11:20 AM
W
Received 15 Votes on 14 Posts
Dodge
318 L? Is this train locomotive?
Old 11-23-14, 11:33 AM
chandler's Avatar
Its only 19,000 cubic inches. I thought it was a 318 cu. in., so I didn't question it.
Old 11-24-14, 12:47 PM
Thanks
Thanks for the reply. Yes, check engine light comes on and then make a "ding" sound when the guage drops to zero.
Old 11-24-14, 01:42 PM
Received 226 Votes on 201 Posts
Just to rule out the obvious - you have checked the oil level, right?
Old 11-26-14, 10:44 AM
W
Oil filter stopped up / messed up / defective ?
By a book on the vehicle , Chilton or Hayes .
Or do a Google search .
God bless
Wyr
