P0121 code
Old 10-17-15, 02:11 AM
P0121 code
2008 Silverado small V-8
Looked it up , accelerator petal position sensor . Cleared the code , has not come back .
Also read one thread , it may also mean the electric throttle system may need cleaning ? Any one know more .
If the code comes back , I may try unplugging and plugging the connector back into the APPS .
Last ditch , buy an new part and replace it . Company truck , boss will pay for the part . I do not mind installing it .
We had another truck limp home ( limp home mode ) for about 60 miles . Had the electric throttle system replaced & it has not given any more problems since .
I am not at all sure I like this fly by wire throttle system . :-(
Expensive solution to a problem that did not exist .
God bless
Wyr
Old 10-17-15, 09:18 AM
the_tow_guy's Avatar
Received 38 Votes on 30 Posts
Wifey's current car (Camry) is our first with gas-by-wire; like you I think the jury is still out and, really, when did anyone EVER have a problem with a throttle cable? I mean, my wrecker is pushing 680,000 miles and 20 years on factory cable. Can't imagine it's cheaper to produce/install at the factory which generally drives that kind of design/engineering decisions.
Old 10-17-15, 10:49 AM
XSleeper's Avatar
Received 298 Votes on 271 Posts
OBD-II Trouble Code: P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
Another site mentions:
Common Problems That Trigger the P0121 Code
Defective Throttle/Pedal Position Sensor or Switch
Dirty or carbon-filled Throttle Bore
Torn or jammed floor mats
Faulty or corroded Throttle/Pedal Position Sensor/Switch wiring or connections
Don't make the mistake of replacing a perfectly good part just because of a code. You can test it with a multimeter. If the code doesn't come back, it may have just been a temporary problem.
Old 10-18-15, 01:46 AM
Seems like some one sells a a cleaner in a spray can ?
Suggestions , please ?
God bless
wyr
Old 10-18-15, 07:06 AM
XSleeper's Avatar
I've used CRC throttle body cleaner... works fine.
Old 10-18-15, 10:11 AM
Pretty much any throttle body cleaner and a toothbrush. CRC sleeper mentions is good.
