Heater blowing Cool Air
Old 10-27-15, 01:23 AM
Nissan Titan 2011 blowing cool air when heat turned on. Rad fluid checked and no issue.
Is it a thermostat; a heat core flush needed; the electronic valve; thermostat stuck open?
Old 10-27-15, 01:33 AM
Received 374 Votes on 351 Posts
Welcome to the forums.
Check the two rubber lines going to the heater core. They should both be hot.
You may have a problem in the hot/cold blend door system.
