2003 chevy S-10 4.3L V-6 chirping
Old 12-12-15, 08:03 AM
Hello again, My S-10 has recently started chirping from the engine on an intermittent basis. I have 104,000 miles on it and this noise comes and goes as I am driving down the road. thought maybe it was the belt but the old soap trick didn't work. Any help would be greatly appreciated.
Thanks, Fritoguy15
Old 12-12-15, 08:15 AM
lawrosa's Avatar
Super Moderator
I have a 1996 s 10.. Chirping would be the pully/tensioner... a/c bearing... alt bearings.
Old 12-12-15, 09:39 AM
I've only been using the defrost occasionally, but the noise comes whether that is on or not. If it is the pulley tension, any idea how that would be fixed? as far as the alt. goes I feel that is okay, but you never know.
Fritoguy15
Old 12-12-15, 10:44 AM
lawrosa's Avatar
Super Moderator
with truck off of course and belt removed check tensioner for play...
https://www.youtube.com/watch?v=ientwYlyGQk
Old 12-12-15, 10:54 AM
lawrosa's Avatar
Super Moderator
also that one pully at the top left that the belt just rides on usually is the culprit... Thats the first one that went bad on me..
https://www.youtube.com/watch?v=AEUe6uKxTv8
Old 12-13-15, 07:58 AM
the_tow_guy's Avatar
With the belt off, check the water pump for play. I recently had an odd intermittent chirp that turned out to be my water pump.
Old 12-13-15, 09:48 AM
I ended up replacing the idler pulley and the belt and no more noise. Thanks, Fritoguy15.
