Gas gauge intermittent
Old 03-02-16, 05:14 AM
B
I have a 2000 Chevy Silverado which has an inconsistent gas gauge. When I fill the tank it registers on the gauge I have an empty tank. After using some fuel it shows what I assume the correct fuel amount. Periodically as the tank gets closer to empty it again registers empty. I would assume it is either the gauge or the float. Any help would be appreciated.
Old 03-02-16, 06:00 AM
Received 857 Upvotes on 749 Posts
Welcome to the forums!
While a sticking float is a possibility I'd closely inspect the wiring [especially near/at the tank] first.
Old 03-02-16, 10:54 AM
Received 4,051 Upvotes on 3,634 Posts
It's also a very common problem for the sender to go bad. It's a coil of resistance type wiring that the float arm slides over. That wire gets rusted and worn out causing loss of a gauge reading. Unfortunately it's not repairable and the fuel pump and the sender is replaced as a unit by dropping the fuel tank.
Old 03-02-16, 11:07 AM
Received 1,273 Upvotes on 1,213 Posts
Floats tend to get stuck and then the gauge doesn't move. I think PJ has the most likely scenario nailed.
