My 1998 Ford F150xlt is sick.
Old 03-17-16, 05:14 PM
bob1908's Avatar
hi all
ecmy problems seams to start off with an airbag code 57 and my battery kept drains so bought new batt so i still had the airbag code and 1 time after going to wal mart i came home turn the truck off carried my stuff in the house came back out and radio was playing i scratch so i my head so after that i started unhooking batt now i got some new stuff going on now i have no dome light no map lights no power windows no windshield wipers no dash lights the key in ignition buzzer no head light buzzer
what does work is it start run drives turn signals work horn works headlights hi and low and heater blower stop lights and rev lights gauges in dash work
i checked all the fuses and relays and all are good
any help would be awesome
ty bob
Old 03-17-16, 05:30 PM
A
Received 124 Upvotes on 107 Posts
I believe there is a body control computer that controls most of the things on your list it could be bad or if you can find a wiring diagram check the power and grounds at the bcm.
Old 03-19-16, 05:14 AM
bob1908's Avatar
thank you for your help yes the gem and fuse box had water in it bc ford has a leaking wind shield problem the upper left and upper right corners leak water so from 1997 to 2004 had this problem if u see water on ur floor board or ur carpet is wet and u haven't drove while it was raining chk it out
Old 03-19-16, 05:21 AM
bob1908's Avatar
oh by the way i called the ford place and the gem mod cost 345.65 and the fuse box 346.55 just remember if u go to junk yard to get it its a 50/50 chance it mite be messed up too expl if the leak has happened in that truck too i found some on e-bay
