Trailer plug wiring harness
Old 04-06-16, 11:46 AM
W
I had to replace old wiring harness on truck for utility trailer. I cut all the wires going to old harness and wired to new harness.I have the round plug and the 4 pin plug in all in one.I can not get it wired back correctly. Please help.
Wires coming from 2008 ford f150 are
White
Brown & white
Black& red
Blue
Orange
Yellow
Green
Wires from new harness plug
Purple
Green
Yellow
Blue
Black
Brown
White
Any help would be appreciated.
Old 04-06-16, 12:12 PM
P
Received 894 Votes on 824 Posts
Do you have a volt meter or way to test the wires?
Old 04-06-16, 01:06 PM
W
Wiring
Can you just tell me how to connect colored wires from truck to colored wires to new harness.Thanks
Old 04-06-16, 03:53 PM
Handyone's Avatar
How did you hook it up and is it still hooked up? Did you connect all the same colored wires together?
For now leave the following wires unconnected (capped off)
Orange from the truck and Purple from the new harness.
Old 04-06-16, 04:46 PM
P
I found this diagram on the Ford forums.
Old 04-06-16, 05:26 PM
Handyone's Avatar
Since you have a utility trailer the only wires you need are the following:
Brown = Stop/Tail
Green = Right Turn
Yellow = Left Turn
White = Ground
So connecting the same colored wires from the truck to the adapter should get you up and running.
If for some reason, the trailer lights don't work or weren't working before you started this, check the trailer ground wire.
The trailer white ground should be attached to the chassis of the trailer, usually screwed in below the tongue area. It may have broke loose and that will cause all lights to go out.
Old 04-06-16, 09:07 PM
W
Wiring
Thanks for all the help.Will try this
