Check spark from coil, 93 Toyota pu V6
Old 05-09-16, 10:10 AM
jjrbus's Avatar
Received 1 Vote on 1 Post
I am muddling my way through a no start, Have it narrowed down to electrical issue. 12V + at coil, coil bench tests good. No spark at plugs.
How do I test the spark from the coil to the distributor without electrocuting myself or burning out the coil. I have a spark tester, but does not match up with coil or wire.
93 Toyota P/U with 3VZE, 6 cyl automatic... Jim
Old 05-09-16, 03:05 PM
P
Temporarily Suspended
Wear gloves or use a tool to hold the tip of the coil wire about a 1/4" from any steel that will act as a ground. Have someone crank the engine. The spark should be orange with a blue tint.
Old 05-09-16, 04:01 PM
Received 1,523 Votes on 1,406 Posts
Just FYI.... most coil type systems are supplied constant + to the coil and the negative side is pulsed.
Old 05-09-16, 05:47 PM
jjrbus's Avatar
Thanks for the responses, greatly appreciated. Jim
