Rack-it lumber rack with rust
Old 06-29-16, 06:33 PM
B
Received 5 Upvotes on 2 Posts
If these have rust on them, are they able to be saved - primed and painted - and still be structurally functional? Or once rust starts, the integrity of the structure is compromised?
I'm looking into getting one, but it has some rust.
Old 06-29-16, 06:59 PM
C
Received 105 Upvotes on 84 Posts
If it's just surface rust with no big chunks of rusty metal falling off, you should be able to remove all the loose rust, prime with a rusty metal primer, and paint. Once a rack like that has seen any use at all it starts to rust (except for the aluminum ones). I've seen some with plenty of rust that were still perfectly functional.
Old 06-29-16, 09:10 PM
Received 3,406 Upvotes on 3,056 Posts
They also make rust convertor paints that convert the rust to a hard paintable surface.
Old 06-30-16, 03:40 AM
Received 738 Upvotes on 645 Posts
Rust conversion coatings work but it is still best to mechanically remove as much rust as possible first!
If the price is right I wouldn't be scared of surface rust.
