2013 Ford E-250 A/C compressor noise
Old 07-19-16, 02:19 PM
B
vehicle has under 40k miles on it and just my luck hottest days of summer and my ac goes out.
im attaching a video of what the ac compressor clutch is doing. it is engaging but making loud noise and not making any cold air.
what my question is if i should change the whole entire compressor, drier, orifice. or if i could get away with just changing the clutch itself. ideally i would like to change just the clutch so i dont have to deal with vacuuming and recharging etc.
suggestions???
Warning its loud. watch your speakers
http://vid1177.photobucket.com/albums/x343/Brett_Ottman/3BF4E9FB-6592-4658-BE7B-9F93AA71F434_zpsloisj4nk.mp4
Old 07-19-16, 08:40 PM
Received 4,056 Upvotes on 3,639 Posts
If you turn the A/C off does that noise go away ?
I don't think it's clutch noise..... sounds more like internal compressor bearing noise.
I have a 99 E-350 superduty. The evaporator coil has a hole in it so I feel your pain.
Old 07-20-16, 04:56 AM
A
Received 124 Upvotes on 107 Posts
would probably change the compressor, drier and orfice tube you can probably find a fairly inexpensive remanufactured or new compressor on ebay or rock auto.
Old 07-23-16, 08:04 PM
B
when the ac is off the noise goes away. i figured it was internal just wanted to make sure before i go and replace parts. of course this week will be the hottest of the summer thus far.
yes i will be getting a new compressor, all new o rings, drier and orifice. thanks for confirming
