dodge 2500 4x4 5.7 hemi
Old 01-21-17, 02:00 PM
I just bought a 2004 dodge 2500 4x4 with the 5.7 hemi and for some reason my oil pressure drops to almost 0 and the check guages light comes on at idle but if I hit the gas it jumps back up to normal pressure is that an oil pump problem or something else
Old 01-21-17, 02:03 PM
Received 176 Votes on 156 Posts
Welcome to the forums!
Have you checked the oil level? does the engine make any noise at an idle?
Old 01-21-17, 04:16 PM
chandler's Avatar
Received 4 Votes on 4 Posts
The "check gauge" warning on Dodge is pretty accurate and has saved my bacon on more than one occasion (alternator, overheating, etc.) Anytime a gauge goes out of parameter, it alarms. With that said, It would appear you either have a failing sending unit (hopefully) or your oil pump has gone south. You would need to drop the oil pan to get to the oil pump and it could be a PITA with the transfer case and front drive shaft will be in the way. Or as Marksr says, you could be low on oil or running the incorrect viscosity.
Old 01-25-17, 09:55 AM
Received 5 Votes on 4 Posts
How many miles on this vehicle?
Was it well maintained?
I would start with a compression test to see if it's "worn out"
Old 02-06-17, 01:02 PM
Received 1 Vote on 1 Post
Slightly worn rods, and mains will cause a drop in pressure, maybe even a little oil use.
Sid
