1995 Nissan pickup brakes
Old 08-08-17, 06:34 PM
R
Front brake calipers were sticking, changed calipers, bled brakes and now when the truck is idling you can pump the brakes and have brakes. But as soon as you give the truck gas, the brakes go to the floor. Any ideas?
Old 08-08-17, 07:35 PM
Received 1,118 Votes on 1,038 Posts
Welcome to the forums.
It would appear that there is still air in the lines.
Old 08-09-17, 03:20 AM
Received 321 Votes on 285 Posts
I agree, I assume you didn't bleed the brakes
Old 08-09-17, 03:58 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Even tho you just did the front you mat also have to bleed rear. If you are alone gravity bleed works well but you have to keep filling master cylinder. Don't let it run dry. After all air comes out close bleed screws and pump brakes you will get the last air bubble out.
Old 08-09-17, 04:47 AM
the_tow_guy's Avatar
Received 55 Votes on 45 Posts
Might also have a master cylinder issue going on.
