2006 Ford 6.0 diesel.
Old 08-13-17, 12:52 PM
F
My 6.0 diesel rough idle. The code p2284 comes up. It says it is the icp sensor. I changed it and check engine light comes on will the same code. Then it will smooth out with a miss in it then it will run at high rpm up and down. Before I go and start changing things I might as well ask first. I was told it was a few things.
Any suggestions.
Old 08-13-17, 01:54 PM
Received 3,415 Upvotes on 3,063 Posts
These two items can also cause your code.
HPOP - high pressure oil pump
IPR - injector pressure regulator
Your lucky you can read your codes. On my 99 7.3L I need to use a special code reader.
Old 08-13-17, 03:11 PM
F
Hi Pete
I changed the IPR last year. The truck has 67,000 on it.
After it is hot it will run great. At initial start up in the morning it sounds like it is going to fall apart
It actually sounds like it is louder on the right side.
