Can you body fill and paint chrome?
Old 08-19-17, 06:14 PM
Can't find replacement chrome bumper. Can I just hammer out the dents, use body filler, and paint over it?
Old 08-20-17, 05:01 AM
GregH's Avatar
Super Moderator
Received 19 Votes on 19 Posts
A chrome bumper can be painted but the qualities that make the surface resistant to rusting will not allow the paint to bond like it would on bare metal.
If you prepare it properly paint will stick but even the lightest contact will peel it off.
Old 08-20-17, 05:27 AM
Marq1's Avatar
Received 172 Votes on 159 Posts
You can but have to grind away all the chrome to get to base metal so primers stick!
If I were doing, I would grind then sand blast!
Old 08-20-17, 05:34 AM
Received 170 Votes on 151 Posts
As noted above paint doesn't adhere well to chrome in decent shape. The only time I've had success painting chrome is when it had degraded to the point of rusting. In those cases sanding the rust off will usually allow the paint to adhere long term. I doubt bondo would adhere any better unless you ground thru the plating.
Old 08-20-17, 06:01 AM
pugsl's Avatar
Received 29 Votes on 27 Posts
Just did a google search of chrome bumper repair and came up with many hits that did not take me ant where.I did find this, don't know it it will help but worth a try.
Restoration Chrome: America's Chrome Bumper and Automotive Part Supplier
