2000 gmc sonoma
Old 10-11-17, 10:13 AM
W
2000 gmc sonoma
Need help trying to correct engine problem. Truck is misfiring pretty often sometime it wll jerk the truck.I have changed plugs and plug wires also fuel filter.None of this helped.Any help would be appreciated. Thanks Also this is a 4 cylinder.
Old 10-11-17, 10:32 AM
Received 294 Votes on 261 Posts
Have you done a compression check? or fuel pressure check?
Old 10-11-17, 01:07 PM
A
Received 17 Votes on 16 Posts
have you checked for codes, or how about the coil packs, when exactly does it misfire does the engine use any coolant?
Old 10-11-17, 02:09 PM
pugsl's Avatar
Received 70 Votes on 63 Posts
Most auto parts stores will read codes for free.
