2008 ford 4wd pickup with automatic transmission problems
Old 10-17-17, 08:31 AM
my reverse works when cold, but stops working after warmup. any ideas?
Old 10-17-17, 08:45 AM
D
Did you do the obvious such as check the condition & level, of the fluid? How many miles are on it?
Old 10-17-17, 09:55 AM
yes, even had transmission servced. 85,000 miles
Old 10-17-17, 10:01 AM
D
Is it overheating? The automatic transmission fluid is cooled through a coil in the radiator. Check the anti freeze level & your thermostat.
Old 10-17-17, 10:03 AM
pugsl's Avatar
Received 70 Votes on 63 Posts
If you have a O Reillys parts store near you, They can read codes for transmission. That is where I would start.
Old 10-17-17, 10:20 AM
OK, I'll try that and let you know. Thanks
