Third brake light positioned such that water can leak in
Old 10-17-17, 01:37 PM
The way this light is angled and only held together by two screws, there's no way water doesn't seep into where the light meets the roof. Is this a cause for concern and if so, what's the least time-consuming fix?
Old 10-17-17, 01:53 PM
Norm201's Avatar
Received 225 Votes on 200 Posts
The easy and inexpensive fix is use a thin coat of silicon sealer.
Old 10-17-17, 02:23 PM
Yeah but then I have to remove the sealer everytime I change a bulb, any brand/type that peels/removes easily?
Old 10-17-17, 02:26 PM
pugsl's Avatar
Received 70 Votes on 63 Posts
Drill a small hole in bottom. Water will leak out.
