No acc power
Old 03-15-18, 02:19 AM
C
No acc power
Hello, I have a 2005 Ford Ranger which I just bought. Has 42k miles and in great shape. There is no power when I switch the key to acc. I replaced the relay and that wasn’t it. Only other items I think it could be are the ignition switch and the ignition lock. Each one is about $30. If anyone can tell me how to tell which one is bad. Thanks
Old 03-15-18, 03:06 PM
Received 1,049 Votes on 973 Posts
Welcome to the forums.
It's not going to be a relay. It may be one of several large fuses in the underhood fuse box.
When you turn the key on....several things happen....
1) ACC turns on
2) IGN turns on
That means more than one source or relay.
Does the door buzzer confirm a key in the ignition ?
If absolutely nothing happens when the key is put into the ignition and turned in any position.... check and make sure the ignition switch is even plugged in.
