2010 ranger
Old 11-08-18, 09:21 PM
2010 ranger
I have a 2010 ranger with a 2.3 and an automatic trans..it's an xl with an extended cab..
I need to replace the computer and I want to order one from ebay but don't know what part number I need.
Any help would be appreciated
THANK YOU!!!!
Chuck
Old 11-08-18, 09:32 PM
Received 511 Votes on 481 Posts
Typically the ECM is used in the entire product line but is flashed (or programmed) for a specific model, group and engine. There should be a long part number on the sticker but when you buy one from Ebay..... you don't know if it was flashed for your vehicle.
I was just looking on Ebay..... there are those that sell modules flashed to your vehicle parameters
Old 11-08-18, 10:08 PM
can I read the number without taking it out?
Thank you so much for the help...
Old 11-08-18, 10:32 PM
I don't know. Sometimes the ECM sits in a plastic housing and just slides out.
Old 11-09-18, 03:48 AM
Received 168 Votes on 149 Posts
I bought a computer for a jeep online and they wanted the VIN as part of the ordering process. I assume that allowed them to flash it for that particular jeep.
Old 11-09-18, 04:19 AM
Thank you.
If it is flashed for my vehicle would the chip key work? Or would I have to have it programmed anyway?
Thank you again!!
Old 11-09-18, 04:22 AM
The one I bought interacted with the chip key fine .... that was about 5 yrs ago. My stepson drove that jeep another year or so after the repair.
Old 11-09-18, 04:49 AM
Thank you. I believe ebay number 312298746021 is one I need. It fits all of the compatibility specs but that doesn't show auto transmission. It says it will fit an auto in the description.
Old 11-09-18, 11:02 AM
If you have the same ECU as the one in the link..... it will be bolted thru the firewall with the plugs on the inside. The label should be facing the engine. Get that number before purchasing a replacement.
Good question on the chip in the key. Ask the seller.
