Hard to Put Into Gear (5 Speed Manual)
Old 01-11-19, 10:22 AM
W
Received 2 Votes on 2 Posts
I have a 1991 GMC Sierra with a 5 speed manual transmission, 6 cylinder, 2WD. I've owned the truck for perhaps 8 years +/-. It sits around quite a bit as it's basically my beater truck for doing jobs around my house (hauling lumber, mulch, etc.). I believe mileage is around 180K. A couple of days ago, I jumped in the truck to make a run to Lowes. I could not shift into 1st or 2nd gear (no grinding sound, just wouldn't go into gear). However, I was able to get it into 3rd. So, I started off slow and drove around my neighborhood. Eventually, I was able to shift into 1st and 2nd gears. Shifting into gear isn't smooth though. I have to sort of force it into gear. Don't know that this is related, but for as long as I've owned the truck, reverse was always not quite right. What I mean is, I would first slip into 1st gear, then shift into reverse. If I just went straight to reverse, the gears would grind a little before I could get it in gear.
Old 01-11-19, 10:44 AM
A
Received 72 Votes on 65 Posts
First guess would be the linkage; worn, corroded, bent, or whatever, so I would start with a thorough visual inspection of the linkage, accompanied by someone sitting in the vehicle to shift gears. The engine does not need to be running for this.
Old 01-11-19, 12:43 PM
Rough Rooster's Avatar
Received 13 Votes on 10 Posts
Check oil level. Your description sounds like it is about out of oil.
Those models were prone to problems,
Hope it is salvageable.
RR
Old 01-14-19, 12:15 PM
W
Thanks for the responses. I'm anxious to check each of your suggestions, but it got cold outside. My old truck is covered in snow, LOL. I'll take a look as soon as it thaws.
Old 01-14-19, 12:48 PM
W
If the oil is low in the transmission, I'm going to feel like a total moron. I have never checked the fluid level in the transmission. No dipstick up top made it easy to forget.
Old 01-14-19, 04:26 PM
Marq1's Avatar
Received 946 Votes on 859 Posts
Unless you are seeing big leaks on the ground I'll bet, lack of use, cold temps, thick fluid, hard shifting!
