What should I look at
Old 01-22-19, 05:31 AM
T
I am looking at getting a 2014 or newer f150, I have the car fax. What questions should I ask to avoid getting a lemon?(I have had bad luck) Is there anything specific that I can look for underneath the engine? Thanks in advance.
Old 01-22-19, 06:07 AM
Received 5 Upvotes on 5 Posts
I Googled "ford f 150 problem years" and saw several answers to your question. I've never personally owned a F150. My future truck will be a Honda Ridgeline if I don't buy another wagon.
Old 01-22-19, 08:46 AM
P
Received 1,840 Upvotes on 1,647 Posts
If buying used I would do a little research into how to spot a flood vehicle. There are many sites that will tell you how to inspect the vehicle for water/flood damage.
Old 02-24-19, 07:17 AM
Y
Received 23 Upvotes on 22 Posts
You might find Ford TSB, technical service bulletins, and maybe some other Ford unpublicized (sp) notices. Are there service records you can see ?
Old 02-25-19, 03:53 AM
B
Received 242 Upvotes on 215 Posts
Tell the seller you want the truck inspected by your trusted mechanic, If you can't agree on how to get the truck to the mechanic, walk away.
