Tow dolly problem
Old 01-23-19, 05:11 AM
dinky's Avatar
Tow dolly problem
I have a new Master Tow Dolly that I use to carry my '16 Honda Civic. My RV is a 2011 Phoenix Cruiser 3100. I've had to replace new tires on my rear after a little over 5000 miles due to both of them badly "cupping". I was getting a lot of road noise from the rear, so I took my Honda to my tire guy who showed them to me. The shocks are good. I can't afford replacing the tires all the time. Has anyone had this problem, and what can I do to solve it??
Old 01-23-19, 05:14 AM
Received 740 Upvotes on 646 Posts
Not sure what the solution is but anytime you tow a vehicle long distance more stress is put on the tires because they aren't tracking the same as they do when being driven. What pressures are you running in your tires?
Old 01-23-19, 01:10 PM
dinky's Avatar
I generally run them at 36 PSI.
Old 01-23-19, 01:18 PM
Received 29 Upvotes on 28 Posts
The tires on the tow vehicle are cupping or those on the Civic? Does the Cruiser have duals?
Old 01-24-19, 06:19 AM
W
Received 60 Upvotes on 52 Posts
I would have the wheel alignment checked on the rear wheels of the Honda.
Old 01-24-19, 07:22 AM
A
Received 73 Upvotes on 66 Posts
Worn shocks can attribute to cupping, and you said your shocks are okay, but I would still be wondering along that line. I don't know if or how much of a factor it might be, but it seems to me that when a vehicle is being towed on a dolly the geometry of the suspension has been altered such that instead of the shocks working straight up and down, relatively speaking anyway, they are now working at say a 15 angle from their intended configuration. Does this diminish their effectiveness or otherwise affect them in any way? I don't know, but seems like it could.
