Occasional loss of braking - Toyota Tundra
Old 07-12-19, 09:50 AM
Received 1 Vote on 1 Post
I have a 2004 Toyota Tundra, and for the past couple years sometimes the pedal will travel freely to the floor and I completely lose braking ability. When I lift off the pedal and press again, braking is restored. It only happens one out of 100 times pressing the pedal, but it is very unnerving when it does (I've nearly rear ended someone). I had the lines flushed with BG cleaner a month ago, but the problem persists. Could this be caused by a leaking seal inside the brake booster? If so, why would it only happen once out of every hundred times then work fine after releasing and pressing again?
I just read online about another Tundra owner (albeit a newer model) having a similar issue. Bled the brakes multiple times, replace the booster, wheel bearings, etc. and still had a problem. Turned out being sticky valves in the ABS unit. The suggestion was to accelerate to a moderate speed then slam on the brakes repeatedly to engage the ABS and exercise the valves to free them up. Or do this on a dirt road at slower speed. Thoughts?
If it makes any difference, I want to say it typically happens at very low speeds as I'm coming to a stop. Does that rule out a faulty ABS modulator? Would a bad brake booster check valve cause this to happen?
Old 07-12-19, 12:39 PM
Received 6 Votes on 6 Posts
would probably suspect a bad master cylinder , the booster would not result in the pedal going to the floor not really familiar with bg cleaner but many do recommend replacing the old brake fluid out as maintenance but I wouldnt ever expect that alone to fix a problem.
Old 07-12-19, 12:54 PM
Are the correct assumptions correct?
- Bad booster would result in stiff pedal (not a soft one that abruptly and intermittently goes to the floor)
- Bad check valve, same result as bad booster
- ABS - would only be an issue with hard braking, not normal braking
This leaves air in the system somewhere and/or a possible leak or a failing MC.
Old 07-12-19, 01:22 PM
Marq1's Avatar
Received 94 Votes on 85 Posts
Bad booster would result in hard, un-assisted braking.
Bad MC would result in no braking, fluid leaking past seals and pedal going to floor but should not be just occasionally!
ABS would not have anything to do with normal braking, it only activates during hard/panic stops and would never cause pedal to go to floor or hard braking.
Air in system would give constant spongy feel!
I would also say it's MC!
Old 07-12-19, 01:41 PM
the booster does not cause the pedal to go to the floor so no its not correct, pump up your brakes several times with your engine off your pedal should get higher as you lose the vacuum stored in the booster then with your foot still on the brake start the engine and your pedal will drop cause the vacuum is assisting to help you push the pedal down further than you could without it, all the check valve does is lock vacuum in the booster so you will still have power brakes to assist in stopping even if you do not have engine vacuum like if your engine died.
Old 07-22-19, 06:08 AM
I took a trip to the beach last week and it was getting worse, so I stopped at the auto parts store and picked up a master cylinder and replaced it when I got to my destination. The issue didn't occur at all for the entire 250 mile return trip home, then resurfaced as I was pulling into my driveway. So I guess it's an issue with the ABS? Stuck outlet/dump valve? Can these valves be replaced individually or would the entire unit need to be replaced? From what I've read, this isn't a DIY job?
Old 08-27-19, 01:18 PM
Just a quick update: I took the truck on a gravel road and slammed on the brakes several times to exercise the ABS. That was three weeks ago and I haven't had any issues since.
