F250 brake system question
Old 07-14-19, 12:55 PM
L
Received 10 Upvotes on 10 Posts
Does the brake fluid in the individual lines to the four wheels circulate back to the master cylinder or does it stay there forever unless it leaks out or is flushed?
Thanks.
Old 07-14-19, 01:04 PM
Received 3,880 Upvotes on 3,477 Posts
Technically..... it doesn't circulate but it does go back and forth. Water and rust get moved thru the brake lines every time the brake pedal is pressed. The brake lines need to be flushed to get rid of water and rust.
