How Do you Restore Nerf Bars Back To Glory?
Old 07-23-19, 09:52 PM
B
Received 3 Votes on 3 Posts
Before installing these bars on new to me 99 4x4 Ranger I would like to restore them to some of their erstwhile glory in the same black.
Has anyone done this? How and what products did you use, how are the results holding?
Old 07-24-19, 02:48 AM
Received 671 Votes on 594 Posts
Is it painted steel/aluminum or are they vinyl covered? If just metal I'd paint them. There are products that will bring back the color on vinyl.
Old 07-24-19, 04:20 AM
P
Received 1,560 Votes on 1,403 Posts
They look like they are plastic covered. There are many products intended to make plastic look like new. Whatever you choose make sure it doesn't contain silicone which will make them slippery. But I have not seen anything permenant. Just like tire treatments you may have to reapply regularly.
Old 07-24-19, 10:54 AM
B
They are steel tubes, step area is plastic. Someone suggested they used a rustoleum bedliner. I have seen utuber use krylon fusion for plastic spray paint. He took it to both the metal and plastic. It looked good I would say.
Old 07-24-19, 01:09 PM
The parts stores and automotive depts sell a 'wax' or maybe it's a cleaner for the plastic parts. It will turn it back to black and give it a little sheen. As PD stated it is something that has to be reapplied every month or two.
Old 07-24-19, 01:17 PM
XSleeper's Avatar
Received 1,527 Votes on 1,371 Posts
First thing I thought of was to recoat them with a bedliner spray... if you don't mind the texture.
Old 07-24-19, 08:26 PM
B
I like the bedliner spray idea. Does it stick to the rubber/step part?
Old 07-25-19, 04:35 AM
P
I would be very cautious about anything applied on top of plastic like paint or bedliner, but paint especially. It might be a trick if you want to flip the truck for a quick sale but stepping on a painted surface isn't going to hold up.
Old 07-25-19, 05:48 AM
A
Received 72 Votes on 65 Posts
I think bedliner spray is worth consideration, but would be apprehensive of it from an adhesion standpoint as well as what the chemical reaction may do to the existing material. So, if the rubber is held on with Christmas trees or other such fastener that can be readily removed I might remove the pads, clean and sand the metal, and use the spray. Otherwise, frankly I would probably go to the auto parts store and see what I could find in the Armor All, Meguiar, or other lines to freshen them up as much as possible.
