Hydraulic cylinder identification on a Case Backhoe
Old 10-25-19, 08:28 AM
Sorry if this is in the wrong section. Did my best to figure where to post this.
Just picked up a Case 480B Backhoe, Serial # 5270076. Sat for 15 years. I had it running after 15 minutes!!!!! Anyway, I replaced a bunch of hydraulic hoses, but noticed several cylinders are leaking hydraulic fluid. I want to reseal them, but cannot find the serial numbers on them to order the seal kits.
Looking at: https://hwpartstore.com/collections/...-backhoe-parts there's several different seal kits for each one, and you need the serial number for each cylinder to order. I've checked the face of the gland, and the cylinder tubes for the numbers, and I don't see any. Does anyone here know where they may be stamped?
Old 10-25-19, 08:48 AM
Received 5 Votes on 5 Posts
Probably go through Case using the serial number. A lot of farm equipment is like that. I worked for an equipment manufacturer who all made all their hydraulic cylinders. Those weren't vended in.
