Nv3500 Transmission
Old 02-26-20, 05:37 PM
C
Nv3500 Transmission
I have a 1994 s10 4.3l v6. I keep having nightmares with this project.. Is the pivot ball supposed to be pulled out by hand? And should it have any play in it? I can pull it out by hand and it has a little up and down wiggle but is tight side to side. Also.. The pivot ball is not wanting to line up with the clutch fork. Can I adjust the clutch fork so that the pivot ball is centered in the hole.? When I move the fork to line it up. It moves back and forth smoothly. I just can't find out if the clutch is suppose to be right against the bearing or not. I get all kinds of answers when I search. Just none of them answer any of my questions. Thanks for ANY help. Very much appreciated.
