Mobile home frame trailer conversion
Old 04-09-21, 08:36 PM
T
I bought a 20' x 84" flatbed trailer. It has the mobile home jack, solid framing, but 2 mobile home trailer axles.
The trailer vibrates/bounces like crazy around 30 and 60 mph. Like it shakes the entire vehicle.
What would you think it most likely is?
wheel balancing?
axle bearings?
u bolts?
bent axle?
thank you for your help.
Popular Reply
04-10-21, 11:37 AM
GregH's Avatar
GregH
GregH is offline
Super Moderator
Received 65 Votes on 60 Posts
As said there are many possibilities.
Mobile home wheels in my area are made like a semi truck wheel.
They are circular shaped, open in the center and mount on several lugs.
Clamps then fasten the rims onto the lugs.
If you have this style of wheel and you are not carefull the rim can go on crooked with symptoms similar to what you are experiencing.
Rims could also be bent.
Another problem is trailer frames often have the wheels mounted in the center of the deck which is not the proper location for a utility trailer.
The wheels should be centered about 60% back from the front of the trailer deck.....not the hitch.
On a 20' trailer that would be about 12' from the front of the deck to the center between the dual wheels.
This axle set back then allows you to easily put 10% of the weight of the trailer and load onto the trailer hitch.If you don't have this much weight on the hitch it could also cause control problems and make your trailer quite unsafe.
There is more but if you check all our suggestions you might find the problem.
O.....one more thing.
You might want to check on the legality of using trailer axles and wheels in your area.
Here they are not legal to be on the road.
The axles are only made for short trip use and usually have a welded backing plate for the brakes.
Also the tires are normally stamped "Mobile Home Use" and are not rated for utility trailers.
Old 04-10-21, 04:56 AM
P
Received 1,574 Votes on 1,415 Posts
All of the above... inspect everything you listed except for the wheel balancing. 99% of trailer tires are not balanced but if you've got a wheel that's way out of balance you can balance or replace it. Most often with trailers the balancing is just a matter of rotating the tire on the rim.
Where is the axle located? How much tongue weight do you have? Does the trailer behave when it is carrying a decent load?
aka pedro voted this post useful.
Old 04-10-21, 10:19 AM
Received 125 Votes on 110 Posts
You left off tires.
They use the cheapest possible tires knowing it just needs to make it from the sales lot to home site.
They also likely where sitting in one spot for years forming a flat spot.
Old 04-10-21, 11:37 AM
GregH's Avatar
Super Moderator
aka pedro, I Mullins voted this post useful.
Old 04-10-21, 02:37 PM
A
Received 72 Votes on 65 Posts
Another vote for axle placement, as Greg mentioned, followed closely by the tires, as Joe mentioned.
Old 04-12-21, 07:08 AM
T
Thank you
I appreciate the feedback. Based on everything you all said it does look like just replacing would be the least worrisome and long term solution. Albeit, not the cheapest way.
around $1860 for 2 complete 7000# axles with 1 e braked.
that means I'd have a 20 feet x 86" trailer with a heavy duty front hitch with a GCWR of around 10000 pounds with an investment of $4300. Would you say that's a good investment?
Or should I just wait on some used axles that might cost around $600 ? I plan on keeping the trailer until I die probably, or until we have electric automated driving trailers haha.
Old 04-12-21, 08:02 AM
I
Received 35 Votes on 29 Posts
Start with the tires, they are almost certainly rejects - just good enough for 1 trip. Wheels could also be bent. Then the axles.
IOW, work from cheapest to most expensive, not the other way around.
Old 04-12-21, 08:39 AM
P
I have never understood why people will settle for only one axle with brakes on a multi axle trailer. If you need and use a tandem axle trailer spend the money and put brakes on both axles.
Old 04-13-21, 11:04 AM
GregH's Avatar
Super Moderator
I agree that one braking axle only is just asking for trouble.
In areas where this is allowed it is seen as money saving but if you ever tow that trailer at or near gross weight the pucker factor would be incredible!
IMO it is dangerous to not have full braking when loaded and really should not be allowed.
Does the price you mentioned include axles, springs, wheels and tires?
What are you hauling and what does your load weigh?
Old 09-27-21, 05:10 AM
L
I had to return a pair of new trailer tires / wheels because they were so out of round they would shake everything badly. So I went to wall work center and did a search by wheel size to determine the diameter & width of the ST tires. Then I found a car tire that size, bought them locally, had them balanced, and rolled up to 90 mph without a hint of vibration.
Old 09-27-21, 06:13 AM
GregH's Avatar
Super Moderator
Ok.
You are putting together a trailer that is able to carry substantial weiight.
Tires designed and stamped for trailer duty do not have to operate under steering conditions and as such have weight carrying capacity as their design goal.
Car tires when compared to similar size trailer tires can carry much less than a trailer tire.
By using car tires you will be limiting the amount you can carry on your trailer and making it very easy to overload and potentially unsafe.
Here, if ever checked by highway folks the trailer will be pulled off the road if the tire weight capacity is exceeded.
The only vehicle tire that closely matches trailer tire capacity is truck load range E tires.
Old 09-27-21, 06:20 AM
D
Received 151 Votes on 124 Posts
I dont know where you are & the difference in trailer prices between locations but I bought a 20' 2 X 3500 (= 7000) lb utility trailer brand new two years ago for about $2800 + tax = about $3200 total. It also had one e brake axle.
If you can get one in your area for that, just sell yours to someone else, let them worry about the problem, take the money from the sale & invest in a new trailer that is factory new & ready to roll.
