2008 Ford F150 V8: P0707, P0607, P1702 codes
Old 06-27-21, 02:18 PM
Dustin_27's Avatar
F150 2008 V8 Supercrew XLT. yesterday these codes started popping up.......yesterday started slipping but would go back into gear fairly easy..... well today I was heading to the lumber yard and it stopped and the battery dide???
Help
Old 06-27-21, 04:57 PM
Received 2,977 Votes on 2,686 Posts
Those codes look like mostly power codes. If your battery went dead you need to find that problem first. If the battery gets low or dies you will get many different codes.
Usually the battery doesn't die while driving. If it does.... the alternator is not charging. If it is charging then there may may be a main wiring problem. I'd be checking grounds under the hood first if nothing else is apparent.
