2005 Ford Freestyle wonít start
Old 06-19-22, 05:12 PM
B
New Battery- Anti-theft flashes- disconnected battery- after 10 minutes tried starting and only radio is on even after key turned off radio still trying to eject from radio-tried the door key- partially turned- even used security passcode to open doors- car started then on 2nd attempt but not on 3rd- back to original issues. Any recommendations would be deeply appreciated. Thank you
Old 06-19-22, 10:58 PM
Received 2,956 Votes on 2,667 Posts
A bit hard to understand. Proofreading and punctuation helps.
Was everything 100% fine before replacing the battery ?
Do you have a second fob or transponder key ?
Have you tried that ?
Have you looked in the owners manual. There are several convoluted ways of bypassing/resetting the security system with the correct key.
Old 06-21-22, 02:57 PM
B
Freestyle
It sat for a few years but I would start it every now and then- I do not have a 2nd fob-could you send a more detailed information in the pics you sent they didnít go through clearly thank you
