Winch on camper
Old 07-28-22, 12:21 PM
A
Winch on camper
The winch on my camper will take the cover up but will not go back down or it will go down but not up what might be the problem?? The switch is working fine please help
Old 07-28-22, 12:28 PM
Received 2,982 Votes on 2,690 Posts
Not sure what cover on your camper you are referring to.
We'd need to know more about what you have.
Does the winch have a name or model number on it ?
Pictures can be very helpful....How to insert pictures.
If it's a basic winch.... the switch will be the only control.
A more advanced unit would have a control relay.
Although your switch mechanically works.... it could be electrically defective.
Old 07-28-22, 12:36 PM
badeyeben's Avatar
Received 46 Votes on 40 Posts
Maybe they are talking about the lift system for the pop up type campers. Then it could be a lot of things. Maybe it is binding up. Maybe one of the cables is broken. Maybe it doesn't get enough voltage. Several things could be the problem.
Old 07-29-22, 05:11 AM
P
Received 1,575 Votes on 1,416 Posts
If it's a pop-up does your mechanism have limit switches to turn the winch off when it gets to the full up position?
Old 07-29-22, 05:15 AM
A
Inside
Sticker on winch
Front of cover
This is the problem child lol any help? It is on a flagstaff Mac pop up 2018 model
Old 07-29-22, 07:34 AM
P
Does the camper have limit switches?
I assume there is a solenoid(s), check to make sure the down one is working.
Old 07-29-22, 03:30 PM
A
Received 65 Votes on 57 Posts
if it uses 2 relays good chance one may be bad making a bad connection for either power or ground.
Old 07-29-22, 03:51 PM
The operation (up/down) switch runs thru the limit switch assy and then to the relays.
You need to confirm power at S1 and S2. Meter is ok. Test light is ok too.
Carefree winch manual - pdf
