Common A/C problems
Old 06-07-23, 11:48 PM
WRDIY's Avatar
Received 41 Upvotes on 39 Posts
Common A/C problems
I have a Toyota Tacoma 2003. It is still running great. However, the AC seems a bit weak last year so I used one of those Artic cans and it worked fine last year. As of this year, there is no longer cold air coming out unless at night. So today, I used that same can from last year but when I connected it, the needle went into the red zone.
Either the can went bad or it is time to bring this in to the shop for an AC recharge. Before I bring it in, is there anything else I should try?
How much is an AC recharge cost?
Thanks
Old 06-08-23, 12:19 AM
Marq1's Avatar
Received 1,209 Upvotes on 1,098 Posts
Somewhere in the system a leak has formed and that needs to be found, they fill the system with dye and use UV light to locate then replace the component.
Had a condenser go bad on my Captiva , I found the part on eBay for $150, they wanted $600, the swap of part and fill was $300.
WRDIY voted this post useful.
Old 06-08-23, 04:56 PM
Received 3,609 Upvotes on 3,235 Posts
The problem could be as simple as a defective valve stem.
If the system is empty.... it would probably be pressure tested first.
Then if nothing was found.... a recharge with dye.
Old 06-08-23, 07:35 PM
WRDIY's Avatar
Marq1, you are right.
There was a leak indeed.
I called my mechanic and asked him for a quote. Pretty much closed to what you listed. A few hundred to do a dye test, a few hundred for parts and a few hundred for fill up.
It turned out that I was using the AC can incorrectly. I had to turn on the Engine first before connecting. Otherwise, it does not detect the compressor, the needle in the gauge will go into the red zone.
When I turned on the engine and turned on the AC to full blast (rolled down windows), then the gauge was on the low side. As soon as I filled it, AC got cold again. This is the same can that I bought from last year. I only used half last year. My truck uses R134a refrigerant.
This also has sealant but still did not seal proper from last year.
https://www.walmart.com/ip/Arctic-Fr...22-oz/16930282
Old 06-08-23, 08:08 PM
WRDIY's Avatar
I have another related question. Once I put one of these gauges on one of these refrigerant cans, I cannot remove the can from the gauge until the can is empty right? Otherwise, all of the refrigerant will be rushing out right? Or does the can have a self seal valve?
https://www.amazon.com/Aupoko-R134A-.../dp/B07F9YKX9S
https://www.amazon.com/ZeroR%C2%AE-R.../dp/B0B1F4F8TS
Old 06-08-23, 10:34 PM
Marq1's Avatar
That hose assembly has a fitting that connects to the can, you slide up the outer sleeve, insert it over the nipple on the can, then release so it can be connected and disconnected as many times as needed.
After looking at the link to the cans they look different than what I have. The one I have has a hole in the top and a collar, these look like they screw on, thinking the two items are not compatible!
Old 06-08-23, 11:31 PM
WRDIY's Avatar
Would you have a picture of your can or one that has the same that you are referring to?
Old 06-09-23, 04:46 AM
Marq1's Avatar
Looks like this!
Old 06-09-23, 10:08 AM
Some places still sell the seal type cans but they are discontinued. The EPA requires resalable cans.
You cannot disconnect the metal tab sealed cans.
Old 06-09-23, 12:10 PM
WRDIY's Avatar
Pete, sorry, I do not understand. Are you saying once I connect a hose to the can, I cannot remove the hose and shutoff valve until the can is empty? I was just wondering is it safe to remove the hose and shutoff valve on cans that still have refrigerant in them when they are not all used.
Old 06-09-23, 01:04 PM
Labeled my picture....
If you started with a can with a flat shiny cover.... you cannot remove the valve.
That is a puncture type can. Once the can is punctured the valve must remain connected.
The newer style with the hole in the middle has a built-in schrader valve.
With this type you can remove the valve and the can will self seal.
Old 06-09-23, 01:30 PM
WRDIY's Avatar
Exactly the clarification that I am looking for Pete! Thank You.
Old 06-09-23, 05:22 PM
A
Received 96 Upvotes on 84 Posts
commonly disconnect puncture style cans yes it will leak out but its not a lot of freon to begin with, this was common practice when this style can was all that was available now that the new self sealing style is available guess you have an option of removing it and maybe it will hold freon till next time you use it, with manifold gauges you can turn off the gauges and leave the punctured can on the fill hose it still may not hold long term though leaving hoses attached and a can of freon under the hood is not something I would want to do.
if it was r134a they are commonly sold in 12 oz cans the stuff you linked to not sure what it is or if you even want it in the system.
