How coolant can get into exhaust?
Old 02-21-24, 06:23 AM
Are there other ways that coolant could get into the exhaust other than a blown head gasket or cracked block?
Old 02-21-24, 06:57 AM
A
Received 118 Upvotes on 103 Posts
most common is likely head gasket or cracked head there may be other reasons plastic intakes melting on the 3800 gm is one I can think of.
Old 02-22-24, 04:42 AM
the_tow_guy's Avatar
Received 251 Upvotes on 203 Posts
Millworker, year/make/model? Some have known issues that we might be able to narrow down.
Old 02-22-24, 09:00 AM
D
Received 258 Upvotes on 206 Posts
With basic info, I agree with Alan.. cracked or warped head or blown head gasket.
Has it run hot recently? Or, even not recently?
Like TTG, a bit more info may help us narrow it down or go another direction.
My first thought was..... let make sure its your issue. Not doubting you, but info like this may help. Why do you say you have coolant in the exhaust? What are you seeing/experiencing? Anything happen leading up to this?
