toilet flapper replacement
Old 07-27-02, 08:51 AM
lisbon village
I have been having problems with my toilet flapper. we decided to replace it . Since the toilet is old - the Overflow tube is cast into the back of the tank. There is not an tube to fit the New flapper on to. How do I get the old flapper off so I can install the new one. Any ideas are helpful.
Old 07-27-02, 02:15 PM
Mike Swearingen's Avatar
Cool
How is the old flapper attached?
Most new flappers have a rubber ring that slides over the overflow tube, or you can cut that out and attach it with the little rubber "ears" beside that ring onto L-shaped brackets at the base of the overflow tube.
Mike
HTML code is On
