slow drain
Old 07-30-02, 05:53 PM
johansonrs
slow drain
My bathtub has a slow drain. I have no idea how to get clog undone other than using chemicals. Any suggestions on how to get to the clog?
Old 07-30-02, 07:29 PM
Mike Swearingen's Avatar
Cool
Try DrainCare.
It is non-caustic and an enzyme-based drain cleaner that eats organic clogs out (hair, soap scum, grease, etc.)
Just follow the directions on the jug. It may take more than one application, depending upon how sluggish the drain is.
Good Luck!
Mike
Old 07-31-02, 06:03 AM
L
There is another product called Pequa, sold at Home Depot and other stores, has worked pretty well for me.
Old 07-31-02, 09:15 PM
W
Received 12 Votes on 10 Posts
Hello, I attack the tub shoe first. I clear about 75% of drains that way. Look into the drain and remove any debris you can see. It never fails to amaze me of how much hair and other stuff I can remove. If that fais I use a snake down the overflow.
Good Luck Woodbutcher
Old 08-01-02, 05:45 AM
Cool
A good flexible homemade "plumber's snake" ideal for tub drains is a piece of braided steel cable.
Bend the strands on the end into little hooks with needle-nosed pliers. Works great for snagging out hair, etc.
Good Luck!
Mike
HTML code is On
