Toilet Seat Bolts
Toilet Seat Bolts
ok i'm having troubles loosening up the toilet seat bolts on the toilet seat they wont tighten or loosen these are plastic bolts and nuts that hold the seat onto the toilet any suggestions as to how to break these loose. Don,
Sawzall = 10 sec
no sawzall, use a hacksaw blade only, wrap some electrical tape around the end you are making your handle with. Will take less than 45 sec each for plastic bolts.
ok got one of the plastic nut things off not actully a nut but found out the other bolt is metal. so plastic nut and metal bolt bolt is diffrent then what i have seen just have to figure out how to free or loosen the other nut up. at least its halfway done. Don,
