Noisy one-way valve (swing valve)
Old 08-09-02, 09:46 AM
I have two one-way swing valves in my fresh water plumbing and both tend to randomly make a water hammer type noise when closing -- brass flapper hitting brass valve body. These are 1/2 sweat fit, off the shelf items, available in any Home Depot or Lowes. I'm sure the valve is the source of the noise because if I access the unit and disable the swing flapper the noise ceases.
Does anyone know where I can obtain a quieter type of one-way valve?
thanks,
barry
Old 08-09-02, 10:48 AM
Mike Swearingen's Avatar
Cool
Replace the brass flapper check valves with spring-loaded check valves with rubber seals. No noise.
Good luck!
Mike
Old 08-09-02, 02:23 PM
Mike,
Thanks for the information on the spring-loaded check valves with rubber seals. The banging pipes would remind me of the old cast iron radiators and the "city" steam that I grew up with. But one last question.
Do you think that I need to locate a plumbing supply specialty store to find these quiet valves or might the local Home Depot carry such an item.
Again, thanks for the information. It's invaluable!!
barry
HTML code is On
