gas hot water heater leak
My gas hot water heater is leaking from the bottom. We use well water and do not have a softener. So could this be from a calcium/iron buildup. does it have to be replaced or can i repair it. if so please advise.
Received 1 Upvote
1 Post
If "from the bottom" you mean the tank, I'm afraid that you have to replace the heater. All else can be replaced or repaired.
If you need any help, do a search on water heaters (above) or come back on this same thread and ask.
We'll be glad to help you.
Good Luck!
Mike
Good Luck!
Mike
