Outside Fauctet
Old 08-16-02, 04:22 AM
Rodney94
Exclamation Outside Fauctet
I am needing some help installing a fauctet.It's in the garage next to the water heater. Got the hole drilled,just need help about the water heater.Their is a valve on the cold side where I won't to go.When I cut in to that line will they be any preasure on it. I'll be using copper lines also,thanks for the help.
Old 08-16-02, 04:46 AM
the_tow_guy's Avatar
Depends. If you turn the valve off and release hot water pressure (open a hot faucet), you can cut in on the water heater side of the valve. If you are cutting in on the incoming side of the valve, you will need to turn off water to the house and crack a cold faucet.
Old 08-16-02, 06:44 AM
Rodney94
Thanks,I'll try it this week end.
HTML code is On
