Septic Tank Feeds
Old 08-18-02, 05:30 PM
Septic Tank Feeds
I have a home with 2 baths - on opposite ends of the house. My septic is on the right-hand side when looking out the back window. I have (presumably) a pipe that comes out of the house and feeds the septic. My question: Will there be two pipes going into the septic or will all pipes eventually connect into one that feeds the septic? AND, if the do connect, will they do so within the foundation or would they combine just outside of the foundation?
I have one toilet that has a slow flush - very slow. The other is fine. A few years ago, a sprinkler tech hit the pipe feeding the septic. It was supposedly repaired. I'm wondering if this is causing the problem. But if everything feeds into this pipe, then both toilets should have the same problem - but they don't. I used a 25' snake and the toilet is still very slow to flush. Anything more than water does not go down.
TIA!
Old 08-19-02, 01:49 AM
P
possibly there is something inside the toilet itself. I would scrutinize it closely, maybe running a toile auger through it. It is possible to have two building drains that meet outside but it is usually simpler to tie everthing together inside.
is the offending toilet even slighly lower than the other one? water will always back up first in the lowest fixture. Can you run water for 10 minutes at other places in the house? try that and see if the suspicious toilet bubbles or overflows by itself. If so, suspect the tank or the sewer line to the tank.
Old 08-19-02, 05:01 AM
We ran a 25' snake which should have come close to hitting the septic. We also ran a toilet auger - bent the damn thing up. The toilet just starting doing this. I'm going to check the vent today. Water running does not back up any more or less when running water in other areas.
Old 08-19-02, 06:49 AM
Mike Swearingen's Avatar
Cool
I agree. The problem is either in the built-in toilet trap itself or the vent to that toilet.
The main septic line usually is one line with everything tied into it under the house.
Good Luck!
Mike
Old 08-19-02, 10:59 AM
Talking
Ok. I sprayed water down the vent and ran a snake - nothing seemed to be present.
I pulled the toilet - it needed replacing anyways due to a crack. Then I sprayed water down the hole with the hose expecting it to back up if the clog was in the drain - nothing.
I looked in the trap of the toilet and cannot really see anything obvious.
I'll keep you posted after I install the new toilet.
Old 09-06-02, 01:55 PM
Talking
OK! I replaced the toilet with one that glazes even the trap (the old one did not). While I was at it, I replaced the linoleum floor with tile and put in new baseboards. I also added shelves. The bathroom looks great and the toilet flushes with no problems.
I looked in the trap and found nothing. The only thing I can figure (and suggested by Lowe's plumber) is that the low-flush power combined with a non-glazed trap, and small attachements created just enough resistence to cause the toilet not to flush.
Thanks all for your help!
HTML code is On
