water pressure valve
Could somebody give me directions on replacing a water pressure valve? When our city replaced the main water pipes in our street, all of a sudden we have rattling pipes when we turn them on and now I find out that our water pressure is too high and we need to replace it with a pressure reducer. It is under the house in the crawl space.
A Pressure Reducing Valve is a water pressure valve.
They are adjustable. You should be able to find it between your meter and your main cut-off valve.
It may be in your crawlspace.
PRV
Loosen the nut, and screw the adjustment UP to decrease pressure.
Good Luck!
Mike
PRV
Good Luck!
Mike
Thank you SO much for such a quick reply. I will check this to see if I can do this, although I am kind of under the impression that this house is so old, that I may not even have one to adjust. I work out of state for one week and then home for one week, so I will check this as soon as I get back home. Thank you again.
