Want to install new toilet
Old 08-24-02, 10:46 PM
chivasgeo
Hello all:
My current toilet has 4 bolts holding it down at the base. I want to install a new, modern toilet. The measurements I took with my current toilet is 14.25 inches from back wall to center of bolt/nut closest to wall. If a buy a new toilet that comes only with holes for 2 bolt/nut(s) holding it down and the wall to bolt/nut measures 12 inches, will this work? Also, what brand(s) out there are reliable, not too expensive, and saves water. My budget can go up to $200.00. Thanks in advanced for any replies.
Old 08-24-02, 11:14 PM
W
12" is the regular rough-in distance for the toilet. The new toilet will work as long as you have a min of 24" clearence (UPC) in front of the toilet after installation. you will have 2-3" space in back of the toilet after installation. Your only other options are to move the toilet flange or get a 14" rough toilet (which usually cost more). Toto makes a good reasonably priced toilet for under $200.
Old 08-26-02, 11:50 AM
chivasgeo
Thumbs up
Thanks again Winslow!
HTML code is On
