Low Shower Water Pressure
Old 09-03-02, 02:08 PM
tkidess
Question Low Shower Water Pressure
Hello,
The water pressure in my shower is very low. On the other hand, the pressure is very good in the tub itself. I've already cleaned the shower head and i've even tried it with the shower head undone.
It might be worth noting that the pressre in the bathroom sink is very low as well.
All help will be greatly appreciated.
Old 09-03-02, 03:19 PM
Mike Swearingen's Avatar
Cool
If it isn't the showerhead, it has to be in the faucet or diverter.
What type of fraucet do you have? Brand? Single handle? Dual handle?
Mike
Old 09-03-02, 03:30 PM
tkidess
well... it's a dual handle faucet. I don't know the brand. It has a nob in the middle that, when turning, it turns the shower on. I notice that even when the nob is completly turned, a somewhat considerable amout of water still comes out of the tub faucet.
Old 09-03-02, 03:45 PM
Cool
Diverter problem.
Pull it, take it to the store for an exact replacement, and install the new one. Should solve your problem.
Good luck!
Mike
Old 09-03-02, 03:48 PM
tkidess
Any idea why the pressure in the sink, same bathroom, would be low too? I don't know what to check.
Old 09-03-02, 08:37 PM
Cool
If you don't have galvanized pipes (only solution = replace), take the vanity sink aerator off and check the water pressure.
Clean the aerator out or soak it in vinegar overnight to dissolve mineral build-up. Make sure that all under-the-sink stops (valves) are wide open.
Good luck!
Mike
