water pressure
Old 09-03-02, 04:12 PM
darsenault
Thumbs down water pressure
hi im don . my home has very low water pressure . wondering if thiers anything i can do . any help would be great thank u.
Old 09-03-02, 08:09 PM
Trying2Help's Avatar
Received 7 Votes on 4 Posts
Hey Don,
Need to know if you are on "city" water or well water. I will assume you are on city. If this is the case, you should have a water regulator connected to your supply line, somewhere between your meter and the input to your house. You will have to locate it, usually buried underground, in a box or in the access panel of you house. The regulator can be adjusted for more water pressure throughout the house, or if need be..replaced.
This will only work if your pressure is bad throughout the house. If you are experianceing low pressure in only selected areas, than we would have to narrow in on those areas.
HTML code is On
