Basement Sink
Old 09-05-02, 02:19 PM
Cwilliams
Cool Basement Sink
I'm going to be converting a dry sink in a bar located in my basement to a wet sink. Luckily, I have a floor drain located behind the bar.
What steps do I need to take to connect to the drain, if possible? I know that I will need to break the existing floor, tie-in, then re-concrete area. What else am I missing, venting, etc.?
Thanks
Old 09-05-02, 02:59 PM
Mike Swearingen's Avatar
Cool
The floor drain should have a built-in trap and be properly tied into the drain/waste/vent system.
If it were me, I would just come off of the sink tailpiece with straight plastic tubing or pipe to drain directly to the floor drain.
Easy, and should work just fine.
Good Luck!
Mike
